It is currently Sun Aug 24, 2025 4:11 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Aug 08, 2013 11:29 pm
First name: Raymond
Last Name: Pipkin
Well, I for one never said a uke was as as much physical work as a guitar. I said it is just as involved. And it can be more effort depending on the approach to either instrument and the materials, skills and tools available.
PostPosted: Thu Aug 08, 2013 11:33 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Process for guitars and ukes are more or less the same. Sure, there are less materials to use, less braces to contend with but at the end of the day they take up the same number of jigs, the require the same processes for making and finishing, and the smaller area doesn't necessarily diminish its difficulty. I'd say it's about 80% of the work of a guitar. Now add to the fact that no one would ever pay more than $1000 USD for a really good ukelele, it makes the prospect of building them for work not very appealing. However like I said I use them to hone my skills and test concepts where the only thing I lose is time rather than materials (which costs money)...
Typhoon Guitars
PostPosted: Fri Aug 09, 2013 12:20 am
First name: Aaron
Last Name: Craig
State: Missouri
All I'm saying is that if you compare apples to apples, it should take significantly less work to build a little uke. This assumes your overall design between uke and guitar are the same, same appointments, same general construction method, etc. If it doesn't take you less time with less work to complete the little uke, you mismanaged your time building the uke.
I'm also not sure I agree that you need all the same jigs, forms, and other special items most folks use when building guitars. Bend on an inch pipe, build without a form; don't have the right bearing size for the binding - use a gramil because there's really not a lot to remove anyway.
Under the right conditions, can building either be exceedingly challenging, labor intensive, creative, and/or fulfilling? Of course.
Aaron Craig
PostPosted: Fri Aug 09, 2013 1:10 am
First name: Raymond
Last Name: Pipkin
I totally agree. The size of the project does impact the amount of time involved. A uke of the same design most likely will take less time. It's just "rewarding", like "guitar" or "uke" are so ambiguous.
It's like building a bridge is hard, but so is setting a stone on a thin band. that said , nobody wants to drive across an unsafe bridge and nobody wants a bridge on their finger
PostPosted: Fri Aug 09, 2013 6:47 am
First name: Rusty
I went back and read the OP's question and here is my answer:
No- it's AS rewarding as building a guitar or any other instrument. I'm not considering income from sales, time to build, difficulty, jigs required, etc. etc.
Others may, that's ok. I'm just saying for me, the build process reward is the same.
PostPosted: Fri Aug 09, 2013 8:45 am
I've always thought of Uke's as toys. I have one and it's most certainly of toy grade. It makes me smile when I try to play it. A friend just sent me this link. An interesting take on a Uke for sure [clap]
Just skip to 2 minutes to get to the good stuff.
PostPosted: Fri Aug 09, 2013 9:24 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
not only it's 80% of the work, but people are only willing to pay maybe 10% of the price of the equivalent grade of guitar.
Typhoon Guitars
PostPosted: Fri Aug 09, 2013 11:47 am
First name: Aaron
Last Name: Craig
State: Missouri
A new, nice but with simple appointments, solid wood factory made Martin soprano uke will set you back over $1K in the states. I believe a fair number of custom builders regularly charge between $1200 and $2000 for one. Assuming a base price for a custom guitar is $3500, a $1500 price tag on a soprano probably comes close to approximating the difference in the amount of materials and work. Check out the pricing for various builders offering both full size acoustics and small ukes. What you see is a price reduction typically between 50-60% from the full size guitar to the uke. Economics dictates the ability to charge the lower fee must come from some combination less work, lower material cost, and market pressure.
Aaron Craig
PostPosted: Fri Aug 09, 2013 12:20 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have never seen a Martin uke in Taiwan, I have seen Kamaka, Big Island, and others and they cost around 800-1000 dollars. With that, I can't think of why anyone would buy a custom uke when in their mind a Kamaka is "top of the line"?
However I do think building ukes will help me understand the dynamics of building nylon stringed guitars...
Typhoon Guitars
PostPosted: Fri Aug 09, 2013 12:55 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Filippo Morelli wrote:
That's simply because you have been unable to convince people to pay you to build them a guitar for the same price as one would buy a Martin or a Taylor. The same story would go for a ukulele.
Many hundreds of Luthiers Sell their instruments every day forasmuch and often more than those big factory names you're pointing to. The marketplace clearly demonstrates that this happens all the time, so you're one off experience is a single data point.
Filippo
In Asia brand and fame is already 90% of what people look for. When someone pays big money here, they WANT to pay for a name, and don't care for the quality. I just can't work out how I'd convince them otherwise.
Typhoon Guitars
PostPosted: Fri Aug 09, 2013 1:10 pm
First name: Mark
Last Name: Parkinson
Country: South Wales, UK
I personally do not like the sound of a ukelele
If I wanted to build something a little different, it would be a travel sized guitar, a baritone or a Veillette Gryphon
Filippo
If a person was talented at guitar making, but is just starting out, how many guitars do you think this person would have to make until his guitars were of a high enough standard to sell them?
What methods do luthiers use to market their guitars (especially amateurs)?
thanks Filippo
PostPosted: Fri Aug 09, 2013 2:49 pm
It took me ten but I was not particularly talented. I'm still not talented in so far as fit and finish but people like the way they sound. It really depends on the person and their ability.
PostPosted: Fri Aug 09, 2013 6:08 pm
First name: D
Last Name: S
My answer is I don't know, since the only acoustic instrument I've built is a dulcimer.
I guess I'll be the weirdo that casts an "undecided" vote.
I gotta say that the ooks I've seen here are spectacular.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Aug 09, 2013 9:55 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
The price range on Kamaka's web site is 1000-2000USD.
PostPosted: Fri Aug 09, 2013 10:03 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Todd Stock wrote:
I am anticipating the day that the only student here to build a uke (a baritone Martin-style 41) finishes up and then smacks his forehead and says 'Wow...I coulda had a guitar!'
Todd, I usually lap up everything you say here like a luthier wannabe. But you've clearly got this backasswards. Why would anyone rather have an overly complicated six string behemoth when it is possible to have a baritone ukulele? :lol:
PostPosted: Fri Aug 09, 2013 10:12 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't agree that Taiwan market is similar to the American market. In Taiwan you can only buy what you'd consider to be run of the mill. For ukes you will only see sophrano, tenor and that's it. Even stores specializing in ukes will not have baritones. Banjo and even mandolin is hard to find and selection basically consists (and this is store the size of Guitar Center) of run of the mill instruments of various price range. I can find non standard stuff like harp guitars or Weissenborns in a small German music store but if you brought a Weissenborn to someone who's been around guitars/stringed instruments for a long time I guarantee you he will tell you he's never seen it in his life.
Typhoon Guitars
PostPosted: Fri Aug 09, 2013 10:14 pm
Tai Fu wrote:
I build ukes because it's cheaper in material than a guitar to build, but it requires the same amount of effort. I won't do a commission on it because people will pay maybe 200 dollars if they are in a good mood for one. It's not worth the effort.
I've sold ukes for over $4,000 multiple times.
The market is there. It's just not as big.
PostPosted: Fri Aug 09, 2013 10:20 pm
First name: Tony
Last Name: C
City: Brooklyn
Tai Fu, I got this:
John, in Taiwan, you can't do that. :D
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Aug 09, 2013 10:25 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I'm sure... but I wouldn't be able to tap into it because if the market is already small in the US, it is miniscule in Taiwan. Remember even baritone ukes are considered unusual in Taiwan.
Typhoon Guitars
PostPosted: Sat Aug 10, 2013 5:28 am
First name: Jeff
Last Name: Crisp
State: Victoria
RustySP wrote:
Come on, It's not like a Ukulele is a banjo!
- Rusty
Member UADA (Ukulele Anti-Defamation Association)
Sent from my iPhone using Tapatalk 2
Unless it is :o Image
PostPosted: Sat Aug 10, 2013 7:52 am
First name: Rusty
Wow! That's nice but I would call that a Mini-Banjo. ;)
PostPosted: Sat Aug 10, 2013 9:04 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Todd Stock wrote:
I'm actually a little excited to see how this one is going to turn out...coco binding on paua purflings. Nice job - like the lathe in the background as well.
Here's a link to how it turned out: http://www.ukuleleunderground.com/forum ... o-Baritone
Machine tools are endlessly useful. ;)
PostPosted: Sat Aug 10, 2013 11:08 am
The real question.... is building a uke more rewarding than building a solidbody mandocello?
PostPosted: Sat Aug 10, 2013 11:27 am
First name: Raymond
Last Name: Pipkin
Yes and no. Helmolz calculated the rewardship of building a uke to be exactly the same as that of building a solid body mandocello, with magnetic pickups, when rounded to four decimal places. However, it is exactly twice as better when rounded to five or more decimal places. I forget where I read that though.
PostPosted: Sat Aug 10, 2013 11:56 am
Maybe some chaldini patterns on the prefrontal cortex?
Users browsing this forum: Colin North and 17 guests
